pierburg 1b3 vacuum routing
(In Topic #92775)
Does anyone have a pic or two of the vacuum hose routing on this one ? Removed carb from car to clean up, and by the time I was to put it back in I had forgot…
There are two hoses from the black thingie at the back of the carb one goes into the short knee shaped hose on the back, no ? And the second one ?, and thenthe long pipe from the back of the carb.
Guess the front hose goes to the dizzie ?
And what with the vacuum reservoir and the T and that valve ? Aaah, what a mess. Any help deeply appreciated. Thanks in advance !
Vidar,
Oslo, Norway
underside of the bonnet lid. Not really obvious
unless you are looking for it.
If you can't find it, I think I could email you a
layout from the 2E2 manual.
Keep smiling, J.
Beetle restoration. Cabrio GTi (black and shiny). Golf driver.
16v MK2. (Oak green) Now on a Clipper (to keep). Audi A8 4.2 Quattro sport and a BMW R65 bike.
… and this for auto 1b3
You can acces these diagrams and more at http://www.vagcat.com/
Some good 2e2 diagrams here (although probably not much use to you) http://www.ltn.lv/~jj/pierburg2e2.html
1983 1100 C
1983 1100 C
Only thing I'm unsure of is the black plastic part at the back, wich outlet goes straight into the other pipe on the carb body, the upper or the lower ? No clear in illustrations.
Thanks,
…from http://www.ltn.lv/~jj/pierburg2e2.html
The upper connection goes (via a T connection) to a small square thermo regulator on the back of the carb.
1983 1100 C
1983 1100 C
