Peirburg to weber conversion
(In Topic #120245)
my peierburg is about knackered ( vauum unit or possible was stat) my auto choke is defo knackered. CAnn't seem to source new carb, have seem Weber onlione for a very reasonable price.
Anyone had exprirence of convertin from peirburg to weber?
Advice please folks and links to any stickys.
ta
Kiley
should i keep looking for a second hand unit or go new. all advise taken with luv and hugs
Mort said
I'm looking at doing this too. I have found a new set / kit for just under £200 + vat is this a good price?
should i keep looking for a second hand unit or go new. all advise taken with luv and hugs![]()
Get new, comes with 1 year garantee, whereas 2nd hand you don't know what is right or wrong with it, saves the hassle and no worries, £200 is about right for a new weber considering £800 from stealers for a pierburg
Pete :wink:
http://www.golfmk1.co.uk
TraceyCab is a satisfied customer…her 1800 automatic cab now runs like a "well-oiled sewing machine"
Replace the "intermediate mounting flange" bonded rubber diddy while your at it!!
Incidentally, I fitted a "TR7" choke switch via Rimmer Bros which I used to illuminate a bulb fitted in the space above the Handbrake/Fluid Level Warning light on the RHS of the dash.
Triumph TR7 Accelerator & Choke Controls - Choke
Some Golfs had a properly adapted H/Brake warning light which has the correct "Choke" indicator….if you find one!
If you go the evilbay route, ensure it is the correct one for your car (Engine Sizewise and Manual/Auto), comes with the adapter plate and fitting kit and maybe get a recon kit from the Weber specialists
http://www.fastroadcars.co.uk/
http://www.webcon.co.uk/
etc
Incidentally 2 - you may be advised to advise your Insurance Company about the change - didn't ought to cost you any more if you tell 'em its a paltry 32/34DMTL
Mk1 GTI
B5 Passat Estate 5 SPeed
Bosch Lawnraker 32
Bosch Lawnraker 32
What makes you think the pierburg is knackered? Sometimes a strip and clean out will solve some carb problems. If the autochoke doesnt work are you sure its set correctly? Sometimes it can be the simpliest thing, might just be getting stuck, or there could be a split in the vacuum system.
I'm not too sure the weber is any better, as I have had both, but on different cars. I see a bit of top end torque on the weber, but that maybe accounted by by different jets. :dontknow:
I'd want to be 100% certain it was the carb before replacing it. :wink:
~Madferret
Mk1 1457cc 5door GX '83
Thanks for the replies. Madferret , i do think mine needs a strip down. what i was going to do was take mine off, go through the very detailed how to and try and get it working correctly first. if no joy then go down the weber route.
I called a carb rebuilders (carburettor exchange) who are near me and this is one of the only carbs they don't rebuild
but I will give it a go and see how i get on.
Plus side is that it has the Weber 36TLP, and also the Pierburg 2E2 in it also so if you ever change car or carb you'll have the books for those too.
~Madferret
~Madferret
rubjonny said
if you swap the manifold for a MK2 golf one yeah for sure![]()
ooooOOOOOooo I might have to have a go at that, presuming that they'd not be too much difference in the jetting, as the 1500 is a de-stroked 1600 and 25cc per piston isn't that much really. The 2E2 should be a good carb I would've thought from looking at it in the manual.
~Madferret
~Madferret
Also, you might be able to drill the 1.5 head to get to a coolant waterway, but this is not something I am sure of, so dont try it on a good head!
The entire engine will drop right in, advantage with that is you can use the later MK2 flange with holes for thermoswitches, since the MK1 inline thermoswitch holdery thing is discontinued. Disadvantage is its 1.6/8, so more expensive road tax than the 1.5.
~Madferret
