Overrun, please help!
(In Topic #125294)
if thats ok make sure the engine isnt getting too hot, i had this in the summer when my fan was duff.
could be carbon buildup in cylinders, this can happen if the carb isnt running right. to cure it get engine hot then remove airbox, dribble water down the carb flap while you hold up the revs. this will turn to steam in the bores and steam clean the inside of the engine for you
Problem Solved.
MK1 1.6 GLI Cabriolet
MK2 GTI 5 Door (WANTED)
MK3 1.9 TD Golf (90miles a day, 55mpg excellent car)
MK4 1.9 SDI 3dr no longer with us!(crashed into a tree)
MK5 Looks like a Golf, Sounds like a Golf but corners like a van.
Mine was idling at 1600 and had to be stalled to turn it off. Had a bit of a fiddle under the bonnet and the vacuum hose to the black plastic diaphragm thing on the front of the carb (sorry) had collapsed. Changed it and the diaphragm thing started screaming, so I turned the adjuster on the front of it out a turn and it stopped. Idle was now up to 2000 (!) so I wound the threaded rod that contacts the metal lower diaphragm rod out two turns. Idle is now down to 950 or so when warm, doesn't run on, all is good.
I would think that the high octane petrol would make the issue worse, certainly seemed to for me.
