Over Heating :(
(In Topic #157237)
Just fitted new water pump and thermostat problem is top radiator pipe is hot bottom pipe is cold, heaters inside car are nice and cosy , The radiator seems to be free of blockages
Thanks in advance for any help guys
Tucker
did you test the 'stat before you fitted it?
maybe try backflushing the whole system just to be sure then run it upto temp and bleed it again..
Take it easy ; )
Cheers Alan
As for making sure theres no airlocks - some people like to drill a small (1mm ish) hole in the 'stat to help bleeding.
I like to set the blowers in the car to full heat, fill the rad to the fill line and then pull the coolant hose of the side of the head to fill up the block which is on on the other side of the 'stat.
When its full run it up to temperature, take the cap of the rad/expansion tank and start grabbing and squeezing every hose you can get your hands on. pop the cap back on, take it for a run then top up if you need to.
dead easy
Take it easy ; )
Take it easy ; )
http://www.vwgolfmk2.co.uk/viewtopic.php?f=37&t=14913
addition step for mk1 is make sure heaters are on hot as the matrix feed pipe has a tap in it unlike mk2 which doesnt
is it a 50/50 mix of coolant and water?
a huge rad overcooling an 1100 maybe?
Take it easy ; )
A lot of the time, motor-factors will have two lines of products, for example GSF do the 'standard' bits and the 'premium' bits, and more often than not the 'standard' are crappy cheap chinese copies of the 'premium' parts which are OEM…
When you take your old 'stat back for replacement, take a mug with you and ask if they have a ketttle in the back (I'm serious!) that way you can check it works before you leave the shop
Take it easy ; )
