oil sump leaking
(In Topic #208183)
the oem cork gasket is fine if you get a decent make, but you may want to upgrade to later mk2/3 rubber gasket. VW specify longer bolts for it, is a good excuse to get a load of socket head allen bolts which are much easier to refit between the sump and box
spec for the rubber gasket bolts is M6X16
