Oil pressure
(In Topic #141108)
Oil pressure
It will hardly look like it's registering?? Is this right?
Hmmm, my a I should look around for a 5 bar one?
So, does your run at 1 bar when warm too?
vw specifiy both 5 and 10bar gauges for the mk1 if you care that much for originality
if the sender is in the head the pressure readings are a little lower than at the filter housing, the minimum pressure spec at the head is 0.3bar which would be hard to read on a 1-10bar gauge. theres no reason why you cant put the pressure sender in the filter housing and swap it for the mfa oil temp sender. that'll be just like a mk2 16v sender arrangement. just a case of extend your wiring to reach.
I have the same problem with my audi oil temp gauge its 0-180degrees so it hardly comes off the stop! operating temp is something like 4mm away from 0.
Just out of interest, I found this useful article which explains not only the fitting of the dials but also what the oil pressure gauge should read.
proper mk1 vdos look different though they have needles that look the same as the mk1 clocks in case you were wondering
edit: like this, though iirc the needles are white?
http://www.ebay.co.uk/itm/VW-Golf-MK1-MK2-GTI-Porsche-VDO-Water-OilTemperature-Gauge-Celsius-Very-Rare-/320854742946
So, I have decided to have a crack with the sender on the oil housing. As the warning part of the sender is 0.5bar this will mean the oil warning lamp will light up at 0.5bar rather than 1.8 bar on the original, right?
take the mfa oil sender out of the filter housing and put your vdo pressure sender there. extend the wire from the side of the head to the filter housing, and put your mfa sender in the side of the head
