need weber info
(In Topic #77106)
need weber info
first problem I looked at tonight, is that somebody had put some sort of foam filter on with a k&n breather, the foam filter was near non exhistant (ripped) so I want to fit the original airbox back… upon removal of the old foam filter, I noticed that it was a weber carb.. I only know this because it said weber on it !! Please note I know nothing about carbs, I've never had a car with carbs !
How do I tell what sort of weber carb it is?
How does the original airbox fit over the carb, there seem to be no bolts or clips, it just sits on top.. its a fairly tight fit, but doesn't seem enough! I've fitted the breather from the rocker cover back to original airbox and binned the K&N thingy too…
Another thing I noticed is there are two thin pipes from the left hand side of the airbox, one of these doesn't seem to go on anything… What are they?
BTW I'm not 100% sure its the correct airbox for the engine!!! but it looks right and bolts to the mount at the front of the engine OK
Also is there a guide to setting up the carb to run properly, or is that best left to a garage?
Any advise will be much appreciated..
Marc
Could you post a photo of what you've got?
Ian
'89 Clipper Auto and '92 GTI Cabby
Ian
Will try and take a pic tonight.
Thanks for info, does anyone know if the webers have these bits that Ian has mentioned?
Marc
AxlFoley said
from memmory i think kthe air box is bolted to the webber differenntly to how it would to the Pierberg, i may have a photo of my old mk2 engine witha webber, i'll have a look.
Many thanks
I've got a manual choke Weber. I'll take a butchers when I get home tonight and post a pic.
I don't know if anyone would agree but I'd get the carb set up at a garage - that way you can get it properly Krypton tuned at the same time (and I'm a lazy sod
You should drink more water.
1664 is 95% water.
Drink more beer?
1664 is 95% water.
Drink more beer?
key_ring said
Hi,
I don't know if anyone would agree but I'd get the carb set up at a garage - that way you can get it properly Krypton tuned at the same time (and I'm a lazy sodops: ).
That 'd be helpful thanks.. I probably will get set up at a garage, but you must be able to get it running reasonably well by hand, withought cutting out etc
marc
here are just the pic on my photobucket account. as you can see they are the oringinal airbox on a weber 32/34. hope this helps you
satelliteone said
hi mawwam, im too the rescue!
Perfect :y: That looks identical to my carb so I assume that is, and pics / instructiona are exactly what I need.
Thanks to all for your help.. hopefully I can get this sorted
Marc
Now on My engine, firstly the part on the carb, where the small pipe goes from the airbox on Satelliteone's engine, mine has nothing there, its blanked off
Also on my engine the fuel line comes from down near the dizzy… there is nothing up by the airbox bracket!! is this just a normal difference or am I missing something???
satelliteone said
I dont think it would be to hard to manufacture your self. A nice solid bit of metal cut to shape.Good sorted workshop and some spare time.
Your prob right, just an s piece really with a hole either side..!
1664 is 95% water.
Drink more beer?
1664 is 95% water.
Drink more beer?
key_ring said
Just adding my pics to join the party!
key_ring where does your second pipe go ? the small one from the airbox? on satelliteone's it goes back to the carb !!
Yours looks like mine, there is not fitment for it on the carb!
:dontknow: :dontknow:
1664 is 95% water.
Drink more beer?
1664 is 95% water.
Drink more beer?
key_ring said
Yep - it is connected to the green plastic bowl. Not 100% what this is called (ops: ) but I'm sure someone will tell you (I'll grab my Haynes manual at lunchtime and take a look if the info is not forthcoming 8) )
Ok mate.. So Satelliteone's goes back to the carb, yours goes to a plastic bowl, and mine goes to nothing !
Itching to find this one out ! :? :?
1664 is 95% water.
Drink more beer?
1664 is 95% water.
Drink more beer?
The Original air box system has an air/suck driven flap. The Air temp switch is located on the side of the box as shown. The idea of this device is to allow hot air from the manifold to be inducted into the box for cold weather running. As the air temp rises the switch operates and throws the flap the other way and a cold air feed is then used. The induction side of the carb , (sucks) through the tubes.
I dont know why i have that tube from the carb, and yours does`nt have this. But a small modification and i think your on the right track. Just splice up the tube that goes to the dizzy. Thats the only thing i can think of.
As too the fuel resviour thingy. Im not sure why yours was taken off. I understand about the float system inside the carb and as the fuel reaches a certain hight inside the chamber, a needle valve shuts the supply off. Iam not sure about the pump back pressure tho. The fuel canister sperator just returns the fuel back to the tank as it not needed by the carb. The pump mind is still operating as the engine is turning.
What your thoughts
Hope it helps.
