Need help!!!!! Water leak
(In Topic #188545)
Water leaking from water level sensor
What goes around comes around
Respect and be respected
MK2 golf pre-90 use the same tank if it helps, or you could use 90spec mk2 or mk3 with adaptations to the bracket. mk2 90spec bracket unbolts if it helps, on my mates car we cable tied it on in the short term and sorted the bracket later. chop plug off the donor and splice to old wires as different, or just bridge terminals or remove 42/43 relay to disable level sensor system
It worked fine but after a couple of years my bottle cracked as it was old so fitted a new bottle and sensor and it's been fine for the last 5 years.
I got one from here.
http://www.ebay.co.uk/itm/VW-GOLF-MK1-MK2-GTI-EXPANSION-TANK-C117-/200649426094?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3AGolf&hash=item2eb7a344ae
