mk1 golf
(In Topic #121278)
mk1 golf
MK 1
Blocked fuel filter
Blocked fuel tank cap breather
pop em off and stick ur finger on one end and suck the other, if you hear hissing you know its them
if theres a crack, over night the fuel will run back into the tank so it will be like starting it afte running out of petty every morning.
hope this helps..
booze and boredom, the greatest mix
NigelO said
oh, and this in the wrong section - smallblock was only the 1093 and 1272 lumps
Oooops, my fault :redfaced:
Sorry
I no longer have the Mk1!! I now whizz round in a Black 1990 3dr Mk2 GTi 8v but the roof doesn't fold back when the sun shines
just under the bonnet as this should be the only place for the lines to be rubber.
i have a 1.1 and they run form the back left of the engine bay up to the lifter pump, (i think yours is electric) and then from the pump to the carb.
sorry i can offer any more help, just look for the fuel pump, or the fuel filter, if you find them your onto a winner
mixerman said
well im not sure on a 1.5…
sorry i can offer any more help, just look for the fuel pump, or the fuel filter, if you find them your onto a winner![]()
1.5 has a mechanical pump and rubber hoses at both ends of the 2x fuel lines.
so the setup is slightly like my ickle 1.1
so they do come up the same side then i take it?
rovers said
well that never helpedi really think it has to be down to the carb anyone got a webber carb or something that will do the job im from the preston area thanks……..
Did you replace the ones near the fuel tank too?
