mk1 golf cabrio clipper
(In Topic #94373)
I'm a new member and i have a 87 golf cabrio clipper. I've got a problem with my car thats just a bit too much. It starts fine but when drive for about 5-10 minutes it just cuts out and i then have to wait another couple of minutes for it to start. I've changed the fuel pump, fuel filter, ignition coil, ignition module and nothing seems to be working.
Do you think it can be an electrical problem.
BYRON
i have changed the following:
distributor cap
spark plugs
ht leads
ignition coil
ignition module
i have checked the following:
fuel tank clean
fuel lines clean
fuel filter clean
carbureter clean
Still can find the problem. does yours misfire sometimes and run on less cylinders? or is it just when you dip the clutch?
Anyone any ideas?
Check the heater hose to the airbox from the exhaust manifold cover.
Also read up on the heater that sits inside the inlet manifold, there's a wire to it in the back of the inlet manifold.
Beetle restoration. Cabrio GTi (black and shiny). Golf driver.
16v MK2. (Oak green) Now on a Clipper (to keep). Audi A8 4.2 Quattro sport and a BMW R65 bike.
