MK1 auto golf starter prob
(In Topic #112635)
I have a mk1 golf softtop 1.8 carb auto
when i gets hot it wont start till it cools down
Then it works like nothing is wrong
The starter just goes click …. doesnt even try to turn
Then you keep trying it and randonly it just starts as normal
I had 3 starters so got a sparky to put them together to make a good one and have had it rewired to a start button rather then the key to try eliminate that circuit and it still does it
any ideas????? please anyone
DuBskiZ
Since its an auto, buy a decent secondhand or new one for peace of mind, unfortunately there's no shortcuts.
check the battery cables are good and clean too, starter needs a good earth and unfotunatly the MK1 gearbox earth location is poor.
VW addressed this on late MK2 and MK3s, buy designing a replacment gearbox -> engine bolt with a stud on the end, they ran the battery earth direct to there which is a big improvement.
Another thing you can do is run a fresh earth from one of the starter mounting bolts direct to battery or chassis earth point, this will ensure starter has a very good earth point.
On my cab I have fitted MK3 battery cables, they're much chunkier than the MK1 item. I had to mod the earth cable a bit as the chassis earth wasnt long enough, I chopped a section out of a second battery cable, ran it from the chasis point and connected it to the MK3 chassis earth with a nut & bolt.
thank
Thanks again
