Low Oil pressure Warning
(In Topic #157038)
1.8 automatic non-injection
Tried to read through topics - are there two pressure sensors on the 1.8 non injection? GSF list three 931VG0030, 931VG0050 and 931VG0050 (White) I am planning to change the pump and sensor(s) anything else it could be and which/what sensor should I buy.
I would add I have recently changed to oil filler cap for a replacement from GSF this would not have any effect would it?
Order a low pressure sensor from VW main dealer, to confirm it is this that is shafted, disconnect the wire from the sensor located by the oil filter, and connect it to the little spare spade connector on the side of your distributor housing, basically earth it out.
If it still carries on squealing, its you clocks that are shafted not your sensor.
