Kangaroo fun with out the fun ! please help
(In Topic #135199)
right heres how it is my 1.8 8v ex engine clipper was running for up until a few days ago i was just driving along at about 50 to scared to go faster lol when out of no where it started to hesitate and then it started to kangaroo very violently i took my food off the accelarator and as the car slowed down so did the revs and then the car cut out so i bumped it back into life and planted my food down it was very very slugish but no kangarooing but as i let fo the pedal back comes the bouncing, i checked all the leads out when i got home found my king lead was broken so i repaired it started the car up started first time and idled as lovely as a 23 year old clipper can i took it for a run down the road it drove fun but then 10 mins later back to bouncing and its been like this since practicly unusable
forgot to add it put a new dizzie and arm on it this morning no change
someone please help
On carbs you only have the one fuel pump which is located at front bottom area of block just above the oil filter.
Clean your tank out as there will be small piece of rust from filler neck in past for sure, have you replaced the filler neck? or has it been replaced in past?
remove fuel sender form underneath the rear bench, there is a small filer on the end wit approx 16 tiny holes, you can simply pull it off and clean it out, whatever you do DO NOT leave it off, refit it.
Then if not been done replace the fuel air vapor separator which is located middle front of block near rocker cover.
Clean the carb i.e remove it and keep it upside down as you do so, therefore no dirt will end up back in the carb.
You got any pics of your carb and block area please for me to look at?
Clean air filter or replace if you have standard paper type
be resolved it's still got no pick up if I
plant my foot down but I think that's more of a timing issue I'm gonna replace my filler neck at some point soon in work thanks again forthe reply I'll
also change the little resovoir that feed the carb and the return
Another option is the vacuum cleaner but it needs to be an explosion-proof one.
