ive replace my pierbug mounting plate still blowing high rev
(In Topic #130637)
then it started blowing like the exhurst was blowing, my mate said you would get the same issues if the mounting plate was duff
i dont want a webber im trying to keep the pierburg so i got the plate she now revs from cold to just shy of 2500rpm but still soulnds like shes blowing
im gona call a duck a duck and say the exhurst manifold must be blowing
unless any of you brilliant people can help
im near manchester airport if any one local can have a look , i can make a wicked coffee lol
many thanks mark :dontknow:
markyptinting
jellybelly said
if the sound is still there it must be the vacuum pipes that control things
you can adjust your idle to bring it down to the right level
also might be work putting a emission tester on it to see weather your rice or lean. if you are this could be adding to your high idle
hth![]()
how do i adjust the idle pal?
can vacuum pipes be replaced ? were are they?
thankyou for you imputt much appriciated
mark
markyptinting
