Interesting carb fault please help
(In Topic #75710)
I'm driving a Golf Clipper 1989 1800cc 8v which has a Pierberg 2e carb.
When it heats up from cold, the revs idle faster and faster until eventually it idles at over 3000rpm.
If I leave the car stationary, once fully warmed up (10 mins?) the revs will suddenly drop to the normal 800rpm and everything will be fine again.
If I then go for a fairly fast drive (which takes plenty of cold air in the front of the car) after a while the revs will switch up again and it will again idle over 3000. I am obviously noticing this problem moreso now as the weather is getting colder.
If I then park up for a few minutes with it revving at 3000 it will eventually drop again.
What could be causing this?
A mechanic had a quick look today and told me it's not the Waxstat.
I had a brand new automatic choke unit bolted onto the side of the carb recently so I don't suppose it's that.
If I park up and switch off when the revs are high I get run on. The engine chugs for ages after I've walked away from the bloomin' thing!
Another guy had a similar problem HERE and I was wondering whether mine's the same.
Many thanks for any help.
I'll get me 'ose today then. Might buy it from Ronnie Corbett's shop……
"Got any 'ose"?
I have had my electrical meter out this lunchtime.
The thermotime valve thing on the back of the carb has a broken wire.
Only the brown one is connected and no the yellow/black one.
Should the yellow/black have 12V (IGN)?
I guess the brown one approaches 12V as the engine warms up (signal from a sensor)?
Is this how the thermotime valve works?
EDIT (AND GOOD NEWS FOR ME)……..
I pulled the two hoses from the thermotime valve and my car idled high. I then blocked the hoses with my thumbs and the car idled perfectly.
It must be the broken cable then.
Can anybody confirm that the yellow/black cable should be connected to 12V (IGN)?
I don't seem to be able to find the other end of the cable if you see what I mean.
All I have is a trailing wire from the connector which plugs into the unit
Stu
87 Cab
its a lot simpler !
just make sure ur heat risers are cleaned out when its done !
Get them wires fixed and it should be fine again
