High idle at startup
(In Topic #197858)
Does anyone recognise this problem? I assume it must be cold start or warm up of some sort, it does have the Audi throttle body and warm up valve conversion, is it likely to be that?
Thanks in advance
Simon
http://www.clubgti.com/showthread.php?195423
and this thread has 8v timing marker pictures:
http://www.clubgti.com/showthread.php?124949
just ignore the 16v parts and the digifant 8v setup procedures. for kjet ignition timing you do that at idle with vac line to dizzy disconnected and plugged, the timing marker on flywheel is the same. For idle and co this is just done at idle, the info about the breather pipe disconnection does apply, but if its really clean then you probably wont notice any CO difference caused by the breather gasses.
the throttle screw orign is worth changing, i bought a big box of generic orings and used the closest size on mine.
in addition look at your AAV, make sure it has a good 12v feed when the engine is running. there is also a Y piece somewhere which has a valve inside that can leak? you can try clamping the air pipe to the inlet manifold see if that drops the idle
I'll see how I get on but your useful knowledge is much appreciated.
My question wasn't even in the right section!
Thanks!
Is this all pointing to the AAC?
Simon
Thanks for your help again dude
My car is doing exactly the same😟 replaced new vacuum hoses & she races up to around 2k on cold.
& I can't suss it out😕😕
What was your outcome???
Many thanks
Mark
