help??!?
(In Topic #74476)
help??!?
If i put my foot right down there is no power at all! it feels almost like it running out of fuel! any ideas??
any suggestion would help no end!!!
When i got the car the fuel return line was blocked off, since i have put a fuel seperator off a mk2 on it (the thing the bolts on the the rocker cover studs) to bring the fuel return line into play! Should i have done this???
As it's a carb, I'd put an outside bet on the coolant channel o-ring being blocked. That tends to cause problems in all gears though. Does pulling the choke help at all?
any idea where that o ring is???
Blocked the fuel return and it was all sorted. If you want the peace of mind of having the fuel return in place, perhaps you could look at regulating the flow return with an adjustable valve or something?
My Build Thread
See Deanso post
http://www.petrunko.aaanet.ru/heynes/volks/1081-04a.pdf
