help??!?
help??!?
If i drive my car anything faster than slow! It splutters! to stop it i have to take me foot of the acc. pedal. Soon as i put back on it starts doing it again!!
If i put my foot right down there is no power at all! it feels almost like it running out of fuel! any ideas??
any suggestion would help no end!!!
Rich - saw your post on deano's thread.
I'd also check the fuel pump delivery and for blocked fuel pipes - causing fuel starvation.
Crazyquiff's Mk1 Golf Parts Emporium
www.golfmk1.co.uk - you know you want to….
Crazy.. do you know the correct layout for the vacume house and fuel lines when a webber is fitted.
When i got the car the fuel return line was blocked off, since i have put a fuel seperator off a mk2 on it (the thing the bolts on the the rocker cover studs) to bring the fuel return line into play! Should i have done this???
soz - don't know the fuel layout - you might block off the return for a quick drive and see if that sorts your problem - might help narrow down the problem
I got this responce on cgti
As it's a carb, I'd put an outside bet on the coolant channel o-ring being blocked. That tends to cause problems in all gears though. Does pulling the choke help at all?
any idea where that o ring is???
I had similar probs on mine when it was a 1300cc on a carb.
Blocked the fuel return and it was all sorted. If you want the peace of mind of having the fuel return in place, perhaps you could look at regulating the flow return with an adjustable valve or something?
See Deanso post
See deanos post!
This PDF is for 1.6 and 1.8 carbed models. It has the diagrames for the vacumm hose connections for the 2E2
http://www.petrunko.aaanet.ru/heynes/volks/1081-04a.pdf
could even be timing?????????
