help needed please.
(In Topic #202822)
Had that on an old Cortina once, what a nightmare that was to trace!
Any other noises before it loses power and cuts out?
When was it last serviced?
Did it give any warnings before this started to happen?
Is it a new car to you?
If its a carb does it have the original carb or a Webber fitted?
Golf Cabrio said
Or a hair line crack in the dizzy cap.
Had that on an old Cortina once, what a nightmare that was to trace!![]()
I had the same problem on A Mk2 Scirocco storm, after replacing lots of bits including the metering head I found the faulty cracked dissy cap which was only a few months old! (I don't buy cheap stuff anymore)
Now after seeing the crud in tanks, id look at that issue first, then clean filters. then try new cap, if filters doing job should stop the crud getting to injectors.
On the drive
Myvalver 89 GTi Grey mk2 16v
Is the Gas less than 1/2 in the tank, you could then pull the cover and the sender and inspect it
Then cover the opened hood with a blanket, and have someone start the car while you are under the darkened hood. Do you see High Voltage Spark Fairies dance about? If so then clean the areas with sandy-paper.
Do you still have the original air box fitted to the webber?
What happens if you wobble the carb when its running or if you have some carb cleaner or similar does the engine note change if you spray some around the rubber gasket underneath the carb as these are prone to cracking/splitting and letting in air.
Also it has got the original air filter box fitted mark is there something else to check? Thanks
If the pipe is missing or if you did have a K&N pancake style air filter you can have problems with the carb freezing at this time of year but this would only happen when it's cold, not sure how long you have had the car so this may not be your problem but I would check the thick rubber gasket at the base of the carb.
Looks like this.
http://www.ebay.co.uk/itm/MK1-GOLF-CABRIO-Carb-flange-Mk1-2-Golf-Scirocco-fitted-with-a-Pierburg-2E-/181847143049?hash=item2a56ef3289:g:QYMAAOSwLVZV3abL
