Help, intermittently losing power then cuts out.
(In Topic #92019)
got a problem with my 1989 clipper cabriolet has a weber carb conversion.
Ive been driving it in quite low revs lately in case that has anything to do with it.
Having problems with losing power an as if its not firing properly but its only intermittent, once it starts i can stop it and end up slowing down until i stop. Then i restart with choke and pump the accellerator loads and it will start and then ok for a another 20 miles or so?
Any thoughts??????
go look through the fuel system section, foxy
Had a look through and found some useful stuff, im going to wait until my tank is low then check for crud with a magnet.
What do you think to this? This morn it was really bad. kept cutting out at idle then suddenly started misfiring and would only drive properly with the accellerator down hard. Also a mate behind said black smoke was coming out when it was spluttering.
Ive recently had a water leak and i remembered one of my spark plugs got covered in water, so later today i sprayed my spark plugs with WD40 to drive out moisture, and this evening it was fine but the problem has always been intermittent anyway.
Do you think it could be moisture? or do you still think fuel?
james
James
Broke down and some dude stopped and checked my distributor for me, and the rotor arm had some corrosion on, so we scraped it off but it is still cutting out on idle although not running on three.
Does anyone think that this is the prob, looked at the service records and the current distributor cap and rotor arm have done 40,000 miles.
Does this seem like a likely time for them to fail?>
I have just replaced rotor arm dizzy cap and spark plugs and its still the same.
It will intermittently struggle at idle and intermittently the timing seems to go out or its losing power and will have to pull over, wait for a couple of mins then restart. It seems to be much worse in mornings and evenings when damp and so i dont think its fuel!
Any ideas???????
They may be doing this intermitently as they may be worse when hot or damp.
For the cost it is worth a try.
Paul
'89 Clipper
'83 Audi quattro
'89 Clipper
'83 Audi quattro
IMG]http://i218.photobucket.com/albums/cc158/whitesta83/DSC00152.jpg
Had this on my mk1 recently, went throught process of eliminating dizzy, plugs etc, checked timing and it advances etc with dizzy so ruled it out.
Pointed to fuel related, after a day break and some thinking i found the problem.
On big block carb engines, at the front where you can see the fuel pump, directly above that is another filter, it has 3 feeds, one to carb, 2 in/out from tank, it is attached by 2 nuts on rocker cover, it's call the petrol vapour separator part number from VW 026 127 177.
On yours it will be metal, mine was a black plastic one as block is a 1.5, i removed this and tapped it onto my hand and black bits were coming out i.e. blocked thus stopping the correct amount of fuel getting to the carb, i had one spare metal type like yours from my original citi engine and fitted it, runs perfect again.
But also as regards black smoke your defo running rich fella, get co's sorted on carb aswell.
Anyway here's pic of part i am talking about, you can get them also at GSF if you wish.
Pete :wink:
