help for few problems
(In Topic #93238)
Firstly what is the red light with a circled exclamation mark - (!) similar to that?
It comes on but then goes once the revs go over 2-3k? and flickers at idle
Secondly when the car is really cold, i.e first start it takes a couple of attempts to start. Normally fires around 3rd attempt. Then idles okish, but if you put your foot to the floor it just dies. Once it has warmed it revs away happily, but will stall when cold.
I have weber carbs on my golfs, in order to keep the warm air flowing, i bought aplha weber air filters, same as K&N for my standard airbox.
A seller on ebay known as fastroadcars sell thems
Pete :wink:
Is that to the right of the steering wheel? Sounds like the handbrake warning light, should be on when the handbrake is on. Seen this problem in a number of mk1's, usually dodgy wiring/earth and or switch (located beneath the handbrake lever itself).
1983 1100 C
1983 1100 C
Would fitting a standard airbox solve the problem, or is there another alternative?
Ta
