help ! clipper runs perfect for half hour then aaargh
(In Topic #92278)
Tian
re help with clipper
help with clipper
re same problem
I had the same on my clipper.
2 checks,
One to make sure the flap inside the filter housing stays open.
A 'Feature' of the carb engines means the flap should stay closed to draw warm air from the manifold up to about 35 degrees (Not even our summers are that good!)
There is a vacuum valve inside the duct that should lift it, but over the years, that gets tired and flops.
Cold air is bad, so a quick fix is to screw the flap shut from the underneath. I did this and never had problems again.
Another one to watch which all of us carb guys know, is to make sure the convoluted hose (The flexy one) had no holes or splits in and is attached securely to the manifold bracket. This is to get as much warm air as possible.
Never fear cold again!
92 Fashion Line cabby (New Girlfriend )
89 Black Clipper Auto (Lost)
83 Black GTI Engineering Resto - (Minty!)
05 PD Passat daily driver (unbreakable)
Still possible you have or had a rotten fuel filler and a tank full or water and muck :dontknow:
worth a go. At the same time, i bypassed the fuel reservoir seperator for 5 miles then plugged back into it again so could have been that too.
