hedgehog?
(In Topic #83662)
hedgehog?
anyone know where the wire from this goes to in the car? mine isnt getting any power at the moment but before i start ripping the car apart id like an idea as to where it goes.
91 clipper cab btw
91 clipper cab btw
what wire :dontknow:
<a><img></a><a href="Login to a private Photobucket.com album
aparently there is a wire from the back of this that goes into the car (so i have been told and can see it) its quite thick aswell.
Have you got a pic?
Rich
Rich
i shall try and get one tomorrow,
good luck :dontknow:
I'm trying to think which bit looks like a hedgehog!!!…….
Is it under the the bonnet?
Audi A4 1.9TDI - Gone
yep its under the bonnet (you have a gti so it may well be different) its a heating element in the manifold when you take the carb off and look into the manifold its like a load of little spikes in there. (i got told it was called a hedgehog)
I have a bunny rabbit - near the car - but it has no wires???
It is a heater to warm the fuel/air mix,the wire goes to a relay in the fusebox,it is controlled by a temp sender on the water circuit,its a alloy tube with 2 sensors in it,usually by the side of the carb in the water hose,my GX has one :wink:
Bert
Bert
thanks bert. was just about to post up some very blurry pics aswell. saves me the embaressment of showing my poor photography skills.
will go check ekta for the wiring diagram now thanks.
Sorry my pic didn't help, no manifold heater on the injection version.
Rob
Rob
thats ok rob at least it was clear, you should see the state of the pic i took this morning (really need a better camera)
Remember to check the voltage, when the car is cold. The hedgehog switches off when warm. The temp sensor is fitted on water inlet top hose flange. There should be two but i cant remeber which one.
cheers everyone, a night out in the cold last night several cuts later and its all fixed.
