Head gasket
(In Topic #191795)
I hope not...
Thanks for any replies
Are you doing lots of short journeys? This would lead to condensation build up without the engine getting hot enough to boil it off; especially with the breather filter fitted rather than the usual breather pipe back to the air inlet system. The K&N will allow the crankcase to breath but wont actively 'draw' the crankcase gases and water vapour out of the engine.
I would clean up the gunky bits, check your oil and water levels and check it again after a while; maybe a few days depending on the mileage your doing. It's always good to look for other symptoms before making work for yourself changing a head gasket.
Does it have a heat exchanger type oil cooler? That is another point of failure leading to oil contamination.
The Red Rocket! My Mk1 Tdi Build.....
My VAG family:
1982 Mk1, PD130 Tdi, 6 speed, ongoing project, to be my daily driver (one day)!
1983 Mk1, 1.8 Gti, stripped out, ongoing project, track car only.
1990 Mk1 Cabrio, 1.8 8v Turbo, G60 ECU, long term project (17 years so far)!
2008 T5 LWB, 1.9 Tdi, to be converted to camper when I've finished using it as a van!
1999 Audi A4 Avant Quattro, 2.5 Tdi, currently off the road, more work required.
2010 Tiguan R-Line, daily driver.
My VAG family:
I'm changing the oil tomorrow anyway so will see what comes out then I can keep an eye on its condition throughout the week!
The head gasket was only replaced 3000 miles ago so I will be mad if if has gone, had the head work done by the best guy in town aswel so wouldn't think it was that either
Member 125 - 2005
