Erratic running engine
(In Topic #190001)
The car starts fine idles smoothly and runs ok till it heats up then it loses all power. You cannot pull away as the engine just dies. So far i've replaced:
Fuel filter
Rubber fuel lines
Rubber carb gasket
Fuel pump
Fuel separator
Plugs
leads
Rotor arm
Dist cap
Coil
All vacuum hoses
the car has had a new fuel filler pipe recently. Timing is spot on and both the vacuum advance and the weights seem to be working. As I say it start first time on choke, idles beautifully, runs OK till it heats up them all of a sudden. and usually when driving uphill (maybe just coincidence) loses all power. Usually if left fore 30 mins you can start it and it will run OK again till it heats up, then it starts all again.
I'm not a car novice ,i've restored an MG midget and know my way about an engine but this has got me baffled. is there anyone out there in forum land that can help??
Any help will be very gratefully received.
I have something very very similar!
Look here:
View topic: Rough Idle Weber Carb - The Mk1 Golf Owners Club
Still no idea what's going on with it!
I'll keep a close eye on this for any responses. This problem seems to come up all the time and usually it is carb flange / filler neck.
One thing that has been mentioned before, a few people have talked about removing the fuel vapour separator…
this part:
I have never tried this myself though so have no idea if it works or not?
1992 Pearl Green Clipper Cab - 16v (9a block, KR head, GSXR600 Carbs)
View topic: Weber carb - fuel vapour seperator question.. - The Mk1 Golf Owners Club
thanks for your input. Ive seen these threads when I did a search prior to posting and I thought that maybe after reading them that the vapour separator was the issue. Weber supply a new fuel line that goes from the carb and its only long enough to reach the separator, so Weber must assume that the separator is still needed. Anyway I tried blanking off the fuel return to the tank - no difference. Runs for a few miles then loses all power just like running out of fuel.
Soo I will once again remove the carb, check the flange, check all the vacuum connections. I will also attempt removal of the tank sender to check the pick up pipe.
Does anyone else have suggestions????
Cheers for your help Joe
It may be that it was set up and running a little weak, in the colder weather it would seem ok but in the spring as the weather got warmer it would begin to struggle, may also explain why it is fine at cold start up and dies when up to temperature.
Just a thought.
The Red Rocket! My Mk1 Tdi Build.....
My VAG family:
1982 Mk1, PD130 Tdi, 6 speed, ongoing project, to be my daily driver (one day)!
1983 Mk1, 1.8 Gti, stripped out, ongoing project, track car only.
1990 Mk1 Cabrio, 1.8 8v Turbo, G60 ECU, long term project (17 years so far)!
2008 T5 LWB, 1.9 Tdi, to be converted to camper when I've finished using it as a van!
1999 Audi A4 Avant Quattro, 2.5 Tdi, currently off the road, more work required.
2010 Tiguan R-Line, daily driver.
My VAG family:
thanks very much for your suggestion. I will certainly give this a go using my trusty colourtune. I'm working now for the next few days so will try a retune Wednesday.
I blew the fuel line back to the tank today and the fuel filter does seem to have much more fuel in it. Whether this is the problem or not- who knows. Getting to the end of my knowledge here and clutching at straws!!!!!!!!
many thanks for replying
Low and behold filter is now full of fuel and car is running fine again. Maybe this will help someone else who is experiencing the same symptoms
many thanks for your input mark, very much appreciated.
Once you look up inside the wheel arch you will see what I mean about a mud trap! I wash mine out before and after the winter but my car is a daily drive.
Can you see the glue around the fuel sender? They are difficult to get undone anyway.
yes will do all that and make a thorough check like you advise of the underside at the fuel filler. Unfortunately I think previous owner has used araldite as the top and sides of the fuel sender are covered. I will get it off but don't want to attack it too much till I have a replacement. cant seem to be able to find a used one and the new ones are around the £145 mark.
Will take note of your remarks regarding the mud traps and have agood old poke around.
Once again many thanks for your input.
Can you run the car without the swill pot? (I'm guessing that's what your talking about taking off and plumbing straight to the carb?)
Tbh I have no idea what I'm doing.
Cheers mousey
