Engine Change
(In Topic #108657)
Engine Change
I have a 1.8 clipper mk1, its a 1.8 carb.
Basically think the engine needs a good old tune up and possibly rebuild, so thought i would find out about appropriate swaps. Any ideas what the most reccomended swap is and on rough prices for fitting one?
Thanks in advance
If i want to change from the 1.8 carb to a 2.0 8v or 16v what exactly will be required?
Does the fuel tank need changing? ECU etc…
I just want to try and find the most sensible swap, both cost effective and suggested by those in the know on here.
Any help will be greatly appreciated.
thanks
Starting from a Clipper instead of a GTI means that you have a lot of extra work to convert certain items up to (or take the opportunity to go beyond) GTI spec:
- suspension
- brakes
- fuel system, if you are fitting/using K-Jet fuel injection
so its much easier to start from a GTI.
The usual questions apply:
- how much money do you have?
- how much performance do you want?
- what's the intended use of the car? day-to-day, 2nd car, trackdays, etc?
I could just get the current engine rebuilt, but thought a change might make sense.
The inteded outcome is an able car, not super fast, just blends in with others if that makes sense. And there isnt really a budget, but wouldnt want to spend more than 1k on the conversion? does that make me sound cheap
So thanks again
Another option could be to fit a 1.8 GTI engine but using the original carb, or a single Weber rejetted to suit. This would gain you bigger valves and a hotter cam, giving 100-105bhp over the stock 90bhp. Also, a GTI manifold and exhaust system would help out (no need to go to a 4 branch for that power level, the stock GTI manifold flows really well as it happens).
So:
1.8 GTI engine
seal up the injector holes with 1p pieces and screw in the top hats to hold them in
stock carb inlet manifold
Weber carb rejetted to suit application
GTI exhaust manifold
GTI exhaust system
all for approx ?200-300, I imagine, main varying factor would be where you locate the carb, and if you go for new or secondhand exhaust stuff.
Stick in the GTI gearbox at the same time, would make it more sporty.
The gearbox at present has just been replaced at a cost of ?400 so will prob keep for the mean time
As for the engine, would you go breakers or are there companies to suggest and or avoid?
Same for carbs, would you go new or second hand?
thanks
