Electric fuel pump for Weber carb?
(In Topic #236073)
To cut a very long story short…. I’m currently on my 3rd mechanical fuel pump in a year, approx 500 miles. They all came from Heritage and all of them seem to work fine for a little while then start playing up.
So to get rid of this annoying issue I’m thinking of fitting a low pressure electric fuel pump and doing away with the mechanical pump, swirl pot and return line, I’ll connect direct from the pump to the carb. (Weber 32/34 dmtl fitted)
The pump I’m thinking of fitting is from Heritage as well, it’s branded USA, and described as a rotary electric fuel pump, comes with an in line filter and is self regulating from 2 to 4psi.
has anyone done this already, it seems pretty straight forward and gets used a lot in the air cooled world.
ive had the all to common fuel starvation issues in the past and got around this by fitting a welding tip in the fuel return line, the only running issue I ever have is pump failure.
Any comments much appreciated
cheers.
After only a couple of hundred miles I then experienced really poor starting issues, one day when it refused to start so I pulled the pump and noticed the lever has jammed, freed it up but it jammed again a little while later.
Replaced that pump with a new one and immediately noticed an improvement in pump pressure, all was well for quite a while but… took it out last weekend, stopped for a coffee after approx 30mins, started up ok but spluttered a few mins later, pulled over, revved it a little then all was well again, drove home, another 30mins, pulled on the driveway then it cut out and refused to start.
I noticed the fuel filter was empty and on cranking the accelerator pump on the carb there wasn’t any fuel squeezing in.
So again I removed the pump and cracked the lever a couple of times until I heard fuel in the carb, now back to normal running but don’t trust it again.
Regarding the electric pump, it has a built in regulator so shouldn’t over fuel but an additional regulator could be fitted I guess as belt and braces.
With my Mk1 Scirocco the fuel return line is straight out of the carb via a rubber hose then straight onto the solid fuel line back to the tank, not sure if yours is the same?
See my videos, Tom AFH
On the golf the pump feed goes to a swirl pot first, this has an outlet to the carb and also has an outlet for a return line back to the tank, currently my return has a welding tip in it to reduce the flow back to the tank (common fix) without this it cuts out every hundred yards, I’m sure the weak pattern mechanical fuel pumps have a lot to do with this problem.
What filter are you running and did you fit the safety cut off relay too? Cheers
After an hour or so of necking, I jacked the car up, found the wire, and using the strip and twist the wires together with black tape to secure got my date and myself home.
The next day I was soldering in a proper splice.
Im now thinking the underlying problem I have is maybe vapour lock, given the last time i had a problem was on a very hot day, after a half hour drive or so I pulled on to the drive, open the gates and drove up to the garage, that’s when it just died, no fuel in the filter or carb when I checked shortly afterwards. After pulling the pump and cranking by hand I got fuel again and all was well.
I’ve been out a couple of times since in not so hot weather with no issues at all.
Given a vapour separator / swirl pot is fitted to the golf to stop this issue I’m a little confused, the one fitted is nice and shiny so not that old, the mechanic I spoke to told me it used to be quite a problem in the past with all the carb’ed cars with mech pumps about. In slow moving traffic or at a stand still the mech pump temperature can get high enough to start boiling the fuel, creating vapour and eventually creating vapour lock.
Any of this rings true with you guys
Do not confuse vapor lock with the swirl pot. That is designed for fuel starvation in turns.
Do you have a upper radiator card installed on your Radiator if yes good, if no then do it.
IT prevents recycling of the engine compartment air from going back over the radiator at a stop. and allowing the engine compartment air to get even hotter.
I never had that type of issue on my MG's, Rovers, or Bug-eyes. The Bug-eye had a Mechanical fuel pump, whereas my MG and Rover had a Electric fuel pump.
CIS and Digi's have fuel that is being constantly re-cycled back to the tank. The 4 second prime on key on helps to prevent vapor lock.
I would verify that all your fuel lines are shielded, once they leave the body. and start their way over the engine.
davearnill said
Hi nedrager. I’ve had a look at that pump and it looks very interesting, as it’s a suction type it can be mounted in the engine bay instead of next to the fuel tank, much easier.
I'm running a Malpassi FIlter King with a glass bowl. I don't have a safety cut out installed… getting ready to swap over to fuel injection so no point now.
I was thinking about insulating the fuel lines somehow to help keep the heat away, at the moment there pretty standard I think and are very warm to the touch, I guess a lot of heat comes from the mech pump though so not sure if I can do anything there.
I took the golf out today for a 20 miler or so with no running issues at all, on returning home I left it running on the drive for around 10mins to see if it cut out again, no cutting out but lots of bubbles and percolation going back down the fuel return line, I’m gonna fit some clear fuel pipe between the swirl pot and carb to see if does the same on the carb line.
I though the swirl pot also helped with fuel vapour issues as well as keeping a steady supply to the carb.
I managed to buy a new top card for the rad last year but am still missing the side cards, I’m thinking of making some when I get around to it, should also help with the heat.
im gonna add some pics and if possible a video of the percolation issue I had today, thanks for the info, learn something new everyday with these old cars.
I like the mounting position you chose for the pump, I was thinking of mounting one on the inner wing as its a bit cooler there, good shout for the filter too, I’m gonna persevere a little longer with the mech pump setup as the car has done 110k on a mech pump plus vw obviously invested a lot of development time on the fuel system, end of the day though I just need a reliable car so still might switch.
are you going injection for power or reliability? I guess you’ll most likely get a good dose of both.
Try adding a longer length of fuel hose to the fuel filler so it's further away from the heat of the engine and exhaust.
What's going on with your oil dip stick holder ?
Replacements are readily available for little money and you know the oil level is correct.
good shout on the fuel lines, I’ll look at replacing those and reposition slightly, I already have new dip stick holder, ready to fit when I get a bit of time, thanks for the advice.
davearnill said
Hi nedrager
The pump itself is mounted on top of the breather on the back of the engine, below the fuel filter. I'm going injection for consistency really. I made 150bhp from a 1.4, currently have a hybrid 1.6 installed. The next one will a 1.4, JE pistons, forged rods, Schrick cams and a lot more rpm… I've never done throttle bodies before so it's a personal challenge as well because I tune my own stuff.
