Does a downdraft Weber need the electronic Idle cut off solenoid?
(In Topic #193283)
Ignition is fine, timing is spot on.
There's a bracket for an idle jet cut off solenoid and its missing, could this be the problem?
James
What the black wire goes to on the front.
The black wire the yellow crimp is to earth the carb. The other black wire is the carb block heater which needs earthing hence the other wire.
Rebuild on the weber is easy so worth doing,
