Cylinder head and GTI cam compatable
(In Topic #185133)
The cylinder head number is 026 103 373 Q. Does anybody know if this is a solid lifter head and if so could a GTi cam (soild lifter type) be fitted to give it a little more pep?
Why did I start this
but if its the original engien it'll be hydro lifters in a J plate and solid lifter cam wont work in it
but it doesnt say what type it is.
It will be original block as everything on the car is original
I woudl use a complete GTI head if it was me, they flow better. go for one without a port between cylinders 3 and 4 as it will fowl the inlet manifold on a carby, plus if you have the original 2e2 carb you'll need to drill a hole here for the coolant feed. no big deal match diameter and angle from old head and drill away
Thanks for the help. Ill let him know and he can make his mind up
for some reason i got it into my head you wanted to buy his cylinder head and fit it to your car with a gti cam, but I really dont understand where I got that from looking at what you have written
