Cutting out
(In Topic #203849)
After leaving it to cool when i got it come it started.
I drove it to work on saturday completely fine didnt miss a beat, exactly what i wonted.
So feeling full off confidence i drove to work again this time not as successful. Same problem as before. Cut out on the way to work and on the way home.
Its a 1.8 manual running a pietberg carb.
Anyone any ideas??
Cheers in advance Ben
I just chop the chips🍳🍳🍳
the warm air one is inside the airbox itself, under the domed bit at the front. it can get sticky, plus if the pipe to it or the shroud is missing it wont work very well
there should be a vacvuum line from it to the air temp sensor in the side of the airbox, and then from there to a nipple on the rear of the carb which can fall off and stop the flap opening
See how long it takes your new fuel filter to fill up with bits and maybe blow back down the fuel line going back to the fuel tank, you should be able to blow down it with your mouth and hear bubbling in the fuel tank.
There is an inspection hole underneath the back seat base were you can remove the fuel gauge sender and pick up and look inside your fuel tank, if it is full of rusty bits get a magnet on a bit of string/wire and fish out as much rust as possible then clean the magnet then drop in the fuel tank to collect the rest while driving.
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=14917
This one by any chance?
You may find it won't fit, do you have a space saver spare wheel?
If so you have the larger fuel tank and you may have problems fitting this one.
It's worth fitting a new rubber hose and jubile clips while it all apart.
If you get the fuel level down to just above the red you don't get any fuel coming out of the tank once it's jacked up at the back.
Give the new filler neck a dam good paint but advoid hammerite as its to hard and just chips off over time.
See my thread about 3/4 way down.
I have a space saver spare and a new filler neck for mine is £100 instead of £25 for a tin top!
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmy-daily-drive-1988-gti#post_1504327
Good luck and let us know how you get on.
