coolant leaking everywhere
(In Topic #92460)
My manual says remove 4 bolts and it should come off. There's somerthing else holding mine on that I cannot see.
Any ideas???Hoses all connected back up tight.
It's easier to work on the pump/thermostat off the car and then I can replace seals etc. Rather than work under the car.
The water pump is probably stuck on to the block through corrosion. Very carefully lever and wiggle/twist it off. Once again, there's a seal, this could also be keeping it stuck on.
I'll tackle it again tomorrow.
If I can get it off I'll replace it all.
<a><img></a><a href="Login to a private Photobucket.com album
Because I tried to replace thermostat from under the car I never got a good seal on its housing. Got it now. No leeks so far. Just tested in sink. Putting it all back togther tomorrow.
I'm in Yoker mate.
