Car Not Starting....
(In Topic #82837)
Its been running ok-ish…
I try to start her today and she clicks but dead.
I jump start her and she starts. As soon as i turn the lights on she dies again.
This has all started since i replaced the arm and rubber grommet that goes in the arm.
Am guessing that my timing is way out and not holding the charge?
Anyone have any clues?
thnx
Bert said
Im not shure what you replaced but make shure the body of the alternator is grounded to the engine block,it cuts out when you put the lights on due to the coil voltage going too low and loosing the spark.
Bert
Hi Bert.
Well i replaced the alternator arm, the one that holds it onto the engine.
I also replaced the rubber bush that goes inside the arm. The one that u screw the nut through to the engine.
What your saying is making sense though.
I presume the battery light comes on with the ignition? and goes out when its running?
my TD had a fault like this,it was the earth strap from the gearbox to the body/battery
Bert
Bert said
put a jump lead to the negative battery post and the other end to the alternator casing,then try see if it charges.
Bert
So i need to make sure the earth strap from the gearbox is on properly? :dontknow:
Rubber grommit for the arm of the alternator. Mines not got one.The alternator chasis has to be earthed to the engine. The big thick wire usually red, goes back to the live of the battery, and a thin usually blue wire, goes to your dash batt light display. Thats really it on charging system.
