ABS code engine alternative for EX type ?
(In Topic #201930)
Wondering if I could use a ABS monopoint injection injectionout of a '91 Golf 3 instead of an EX engine when I change out the monopoint injection for the complete EX carburetor setup ?
Are there other things that need to be changed / altered or just not a good idea ?
BerT3
rubjonny said
the ABS lump is similar to the older 1.8 engines, however it has a block breather on the front where you need to mount your carb fuel pump. apart from that it'll all drop in, so if you were to wire up an electric fuel pump then you'll be sorted
Thank you - that's what I thought too
Regards,
BerT3
Will save me a lot of time
Is the head the same ?
Pro's or con's on this idea ?
BerT3
