a few silly questions
(In Topic #78890)
![gorilly in the usergroup ‘Regular’ gorilly in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
last night i took the rocker cover off my 1.8GL so i can sand it down and spray it, im going to replace the gasket, ive heard of putting some vasaline on the gasket before i put it on… is this right?
what else should i do while its off?
another silly question… what is the trick to those waterpipe clips? i use some mole grips (they dont lock) but its fiddley!
thanks
![:o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/shocked.png)
Audi A3 1.8T (1999)
mk1 Golf cabriolet (1990)
mk2 Golf GTi 8V (1990)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/AvatarUploadedByTapatalk1451991667.jpg)
![volkswarren in the usergroup ‘Paid Member’ volkswarren in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![volkswarren in the usergroup ‘Local hero’ volkswarren in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Regards Volkswarren
![la6vmk1 in the usergroup ‘Regular’ la6vmk1 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Gasget
Replace rocker cover gasget with 1 peice rubber one form mk3 GTI 1.8. You will also need to replace stud screws and nuts to make it work. Part # N10186301. Cork ones dont last long and soon start to leak.
Just twist the clips of with water pump pliers or mole grips and replace with jubilee clips.
Vasaline ??????
volkswarren said
if its a new gasket you don't realy need to put anything on all grease/vasaline does is sticks it to the head to stop it moving while u drop the cover back on, but a new gasket shouldn't really move, large pipe grips/adjustable pliars (oops spell check!) are good for the clips but mole grips adjust them so they lock just as the clip is fully open, but if they slip and catch your finger you'll know about it belive me it hurts!!
lol i have the biggest pinch on my finger from where i slipped with one!!
thanks for that its a cork gasket btw.
just sanded the rocket cover down, its all nice and shiney now. just got to primer it, rub down, primer, rub down then pain black engine lacqer on it!
Audi A3 1.8T (1999)
