1990 clipper cutting out problem
(In Topic #76243)
have also noticed is when i press the accelerator at idle from cold start their is a slight pause then it will rev cleanly(albeit better than ever before) but when it ticks over it still fluctuates a little & feels like what i can
describe as 'dropping revs' (seems to drop more than gain when it
fluctuates). any suggestions
Life Member
Also check a good clean supply of fuel from the fuel pump to the carb by taking off the hose at the pump and letting the fuel into a glass jar.
Rajan
Check you VAC pipes too that they are all fitting snug. Another option is to clean the carb by stripping it. Blow out all the Jets with an air line.
Other than that its timing of sorts.
Hope it helps.
Regards
The problem I have is the dreaded cold start problem know to Golfs of this era, where the car will stall/cut out very quickly
when starting from cold. (Note: if I get the car to normal running temp from standstill , it will run ok unless it cools down, then the usual cutting out problems)
I have a new carb fitted etc/new fuel filters/pipes/all leads/spark plus/distributer cap etc etc
New starting motor/coil/battery is only 3 months old. All the fuel supply is apprently ok & clear/clean fuel gettign through.
All this has been changed over a couple of weeks, yet still the same problem remains & its costing a fortune -albeit when/if finally solved I should get a few years use out of my car
I have ordered a new pipe from the 'manifold to the air filter', but surely this cant cause this problem on its own!
Any suggestions would really really be appreciated, as there must be something I have missed!!
satelliteone said
Does it run ok when its hot? and have you the pierburg carb?
yes & its a brand new pierburg carb, couldnt find a weber
Steve_Matthews said
I'd be tempted to take it back to wherever it was that fitted the carb and get them to set it up properly!
Its fitted perfect, my uncle has in the trade (40 years experience), even he's baffled!! The carb come from a guy on ebay who specilaizes in vw golf carbs, who is himself an ex vw employee of 30 years..comes with all test sheets etc,which we also got copies of what the readins should be from vw, when warm the car actually runs better than i have known it in the 10 years i've had it..but something is causing the aggro..really baffled me!!
Just for info, check your VAC pipes. This will give you info for placement.
http://etka.auto2.ru/vw/GOC/1984/44/49/492247/
You might not have Part 25. on yours. Also you might not have the MFA VAC guage either. Part 15 is a one way return valve. Check this by sucking one end and them blowing.(SOUNDS NASTY)..lol Got to be the right way round and working ok.
http://www.clubgti.co.uk/forum/forum_posts.asp?TID=94406&PN=12
One way or another you will find out out what is causing your problems. Just takes a little time.
Check the Fule shut of valve on the side of the carb is energised.
Check the Timing.
Set the Fast idle Screw.
TT
satelliteone said
When it is cold you have to manually keep the revs well up to run? or else it will cut out, and then have to restart the engine.
yes!! thats exactly it(but it don't cut out straight away & starts withing secoonds of retrying, but when warm it runs perfect!! It did need a new carb which didnt help, just other bits..I know its a process of elimination, just frustrating. Will send the comments to my uncle so he can check all.
at least I'm learning about my car!!
I now still have the same fault after a new distributor & pipe from ?manifold to air cleaner?.
So far:-
New choke & carb (plus gaskets)
New pipes/tubes/fuel filters
New starter motor
New plugs/leads/plus other electrical items to do with distributor cap etc
New air filter
New coil
New ?earth? wires
Everything on this forum that has been advised, has been checked?please help,
Cars worth to much to scrap(plus I cant afford it anyway)
Any vw specialists close to Portsmouth, please let me know. I?ve rang pete cooper the local franchise & they want ?90 a hour!!
If i rule out the carb here at fault, then i come down to a cold problem. But the carb has a system in place for cold running. The waxstat Choke idea and it autos on the cold start for revs.Have a look on top of the carb when cold, see if the choke flap is over.
I wonder if your waxstat is getting hot water? I have heard that there is a O ring in the inlet manifold that can get blocked with gunge. This can cause cold running problems. as the hot water cant freely get around too well.
http://etka.auto2.ru/vw/GOC/1984/44/49/491869/
The pic aint that clear on the seal, Part 32. Need to confirm this with my version of ETKA.
If your carb is 100% ok lets say with this idea, then it would run always with the choke on. Im not too happy with this idea causing your problem.
Two things comes to mind, either the mixture is too weak when cold (no choking) or there is fuel starvation for some reason. Maybe a blocked jet, badly set up carb,faulty fuel pump,airing on the intake somwhere.
You have changed a lot of the electical system so i would rule that out, and due to the fact it runs ok when hot. It really points to the carb. I would be rather miffed if i was you by now. I had peirburg problems with my car as it was getting on a bit and time for a recon unit. I opted for the weber from advice and glad i did. Such an easy carb to work with.
Ask your mech that does your work just to go through all the possibles, pipes, water pipes getting hot ok around the peirburg. Inline fuel filter. This might be a bit drastic but you might have to stip the carb and give it a bloody good clean. If this all fails then ask the guy you bought it from to do a retest on the carb.
Is so easy thinking what it could be, but with out being there and listening to the car iam not really going to find out the real reason is.
I really hope it helps.
carb
im in all day saturday got some other cars to fix so pop it round if you can join the party
Ian
'89 Clipper Auto and '92 GTI Cabby
keep your chin up, theres always someone that knows (bert or mi dad) :wink:
cheers,
paul
