fuel pump power supply ?????
(In Topic #117902)
Thanks.
Re: fuel pump power supply ?????
vwgolfm1 said
could anyone tell me if it is ok to route a 12v power supply from the battery straight to the fuel pump
OK? I guess that depends, it is not the most safe thing you could do, but it will work. Just try to remember to switch it off if you happen to have a wreck, not wishing that on you, so as not to make a big fire.
The correct port for the ignition live to pump is PIN 14 in the Black plug on the fuse panel. It'll work off your key if you have the correct fuel pump relay in position 2.
what engine have you fitted?
92 caddy, Now stripped for full rebuild
83 golf gti R1 carbed 16v(soon to have 1.8T)
07 Leon FR TDI daily
Cambridgeshire regional host
I guess its ok to do this as a temp measure to get the car somewhere, just dont crash
