horn not working
(In Topic #111983)
horn not working
ive checked the horn, the fuse, the earth on the column (all fine), when i touch the copper strip to the steering column it works, but i cant hear the relay clicking, i would of thought the relay was ok if its sounding when its earthed out? :dontknow: Has anyone got any ideas as i have it boooked in for mot next week.
Chairman
v
v
v
v
v
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=electrical-faq_2%2Fhornnnnnnn_2
Dan
Chairman
My copper ring is slighty worn (
I now set my steering wheel just off centre. It used to annoy the hell out of my OCD but I've learnt to live with it now!!!!
Have you also tried wiring the horn direct from the battery to make sure that they do in fact work??
Chairman
If you start adding new buttons to the dash where will it all end…. only one place, a wiring disaster.
Do it once, do it right. Go to a professional if you can't do it.
The MOT station may even be able to sort it for you to get it through. :dontknow:
aky31 said
found the problem its the earth strap from the column to the rack ow heres the next problem i cant get at it to change it as the 4 branch is in the way is there any other way of earthing the column to the rack ?
Think i have the same issue m8, i have no earth to the column/rack.
Where is this earth strap? i have a 4 branch as well so il let you know if i find a solution
New project - Aero Blue 86' Mk1 Golf 16v Cabby
Pride and joy - Helios Blue 89' Corrado
aky31 said
cheers mate the only way i can think of fitting a new strap is to remove the steering rack
where does the origional one go from / to?
Does it fit to a certain point on the rack?
Sure you could get in there with a 4 branch
Horn now working lovely jubbly
