last chance on 88 cabby with common unsolvable problem
(In Topic #106923)
Yes, that's it the common fault of going a few 100 yards and then the revs drop, kangaroo's a lot and then stalls.
This isn't the 1st time I have been on here asking about this, I have had…….. new leads, dizzy, rotor arm, plugs, ignition pack, coil replaced.I
then I changed the fuel filler neck and hoovered the tank. Changed the in line fuel filter, changed the fuel pump and this week the carb. Still doing the same thing, driven it short distances for 2 days no hassle and then tonight could not drive it 100 yards again.
Please somebody help!!!!!!!!!!!!!!!!!!!!!!!!!!!
All the suggestions that have been posted before I have looked at to no avail
Lamby
Member 125 - 2005
Member 125 - 2005
Member 125 - 2005
Member 125 - 2005
yes bud a carb model will try and post pics its an 88 cabby
Member 125 - 2005
if its had a new carb and is doing the same thing then that would rule out the carb
what else has been changed mechanical pump?
Website Manager
With all the checks and changes that you have made I would begin to start to suspect a problem with the cylinder head, either a crack, sticking valve(s) or a massive carbon build up.
Have you run a compression check ?
An engine will judder and stall if the mixture is too rich or too lean, lack of or reduction in spark or if the chamber where combustion takes place is the wrong volume for the mixture.
Can you smell fuel when it stalls?
Are you absolutely sure that there are no inlet leaks ? These can change with heat, spray some carb cleaner around the inlet and pipes and listen for engine note changes. However to stall would have to be a pretty big leak !!
Website Manager
A simple check would be, when it stalls check to see how much fuel is in the carbs float chamber, you will probably have to take the lid off the carb to check this. ( In my beetle days I had a twin choke nikki carb that had a see through window into the float chamber, very neat).
If the chamber is empty then you need to see why, I think that there is a fuel cut off valve above the float chamber, that could be sticking closed. Is the pump failing to deliver fuel or an electrical problem?
Website Manager
Also check your earth straps, could be they're corroded/damaged.
~Madferret
Mk1 1457cc 5door GX '83
