2litre Orange mk1, The 7 year saga continues, wiring help needed!
Orange mk1, update 5/4 quarry pics
the starter should have big red to batter and small re to fuse box D Plug ( the white multi plug)
max
\sunset orange?
Kudos to the painter!
whaaa
RESPEC!
yeh apprently it needed a lot of coats and has to be thinned a lot to make it real deep, came out well though
madmax: wicked mate, i do love a good small engined golf, im almost wishing i put one back in mine, with just a 5 speed gearbox too!
tips for not having a fire: check all your rubber fuel lines and replace them, probs about 20 quid in fuel line, also check the clutch cable hasnt rubbed over the fuel pump ontop of the engine too much, as this can cause it to leak…most importantly check that the rubber gasket in between the carb is secure, with no splits etc…worth replacing, abotu 12 quid.(mine was brand new)
as for respray, thats like asking how camp is dale winton? depends what you want…
a GOOD respray with an oven bake finish, with a little bit of welding and generally what it takes to bring a car up to a standard where it is ready to paint, you are looking at about 2-2.5k for a really good job
my advice is strip literally everything minus the dashboard, sand down all the inside, get it in primer, and if you think you are any good, prep the outside too, the more prep you do, the less it will cost, as the prep is the timely part!
thanks for the support on the colour, i think its growing on people lol
ive got 9 days to sort out all manner of problems, along with actually getting it running, i dont know that its actually going to happen b4 i go to uni….hopefully ive got a fella who knows his stuff coming round to sort out this damn engine!!
wish me luck, i really want to take it to uni, if its not doable in time ill buy a rubbish mk3 polo coupe or a mk2 golf….we all know what id prefer to drive
thanks again
JJ
what parts of the wiring are you unsre of ??
can you get pics of all the wiring that youve fitted
also you said it backfired have you checked the plug leads are round the right way :dontknow:
after a quick search you should have
green to tci control unit
black to tci control unit
black to fuse box D plug
red/black? to tci
id double check what you have i think your coil wiring is the key here
im struggling with time this week as ive got to get this mk1 on my drive finished before i start a new job on monday so you may have to do some fault finding on your own i can however ring you and ask silly questions about what wiring you have where just to double check
position 1 on the coil red/black and green
position 15 on the coil black
can anyone else confirm :dontknow:
thanks
JJ
i think its either coil wiring or plug leads which is an easy mistake to make
you can ring me any time i may not awnser if driving tho :mrgreen:
evrything else looks ok
how many wires do you have on the coil?
then there are wires coming from inside the car (ive been told i dont need the black one) does this mean it is ok for earths though, would it earth through the positive terminal, or should i run an earth to the chassis.?
yeh u will probably get lots of phone calls after work lol, u have let yourself in for it now!!
haha
thanks again
JJ
JJ
from alternator 1 x big lead to starter then from starter to battery
battery earth to chassis leg then gearbox
the black lean inside maybe the rev counter wire?
if it spins over then struggles id say timing plug leads around the wrong way not an earth issue
i think your pretty much there just a couple of wires to swap and check timing did you take the dizzy right out or just the cap
are you talking about the black wire which i thought might be for the condenser?
also, yes the whole dizzy came out, as well as having had the cap off too…
hmm..have i done something silly then?
projectgolf said
what do you mean when you say 'the black lean inside maybe the rev counter wire? '
not silly but if you didnt put it back in the same position it will throw the timing out
im not sure if you can put it back in wrong but you can twist it so its out like whenyou advance retard the timing
so jobs for tommorow
time engine up and see where rotor arm points then loosen dizzy and adjust so plug position one points to rotaor arm if needed
rewire coil
fire up and drive away 8)
quote]
the black wire thats spare could be rev counter just ignore it for now
yeh, ill find tdc and adjust accordingly….is tdc, where the big wheel ontop of the engine lines up with the rocker cover, like when you're doing a cambelt?
again…stupid question unles you know
JJ
your so close you wouldnt believe it im just gutted i dont have the time to do it for you tbh youve done a blinding job and it would be ashame to let someone else finish it now if im honest :wink:
