mk1 GTI - Oliver Reed Edition
(In Topic #83309)
Just wondered if people could post what kinds of MPG they are getting from their GTIs.
I have a '83 1.8 GTI and it is VERY thirsty. I don't think I even get 20 MPG on the motorway, and the less said about town driving the better.
The exhaust emissions always look clean - no black smoke or anything, the engine sounds good (no knocking) and there's no puddles of petrol under the car. If anyone could suggest things to check that would be very helpful.
Cheers! 8)
1983 Lhasa Green GTI
might be worth getting the emissions checked out, I know mine's running a little rich but it's nowhere near as thirsty as your Mk1
apart from the obvious checking all the fuel lines and getting the emissions checked I'm not sure.. maybe someone else has had a similar problem on here
Could you recommend somewhere good/reliable in the Berks area where I can get the emissions checked please?
Divide litres by 4.54 to get gals and divide your mileage by the gals.
Guestimating by "10 quid gets me 100 miles" or "I can do 200 miles before it get to the 1/4 full mark" ain't accurate enough.
I get @35MPG on a run and have seen 40 ish taking it gently and 30 if pressing on.
35/4.54 = 7.709 gallons
174/7.709 = 22.6 MPG
Pretty rubbish. Imagine what urban consumption I get! :doh:
I get @35MPG on a run and have seen 40 ish taking it gently and 30 if pressing on.''
ditto
rebuild in progress....
Benici said
Sorry for putting the post in the wrong section.
:wink: ah don't worry about the wrong section mate!
TBH.. I've not had mine checked out yet
You have probably seen this but here are my figures:
1.8 GTi Cab over 342 miles at an average speed of 52 mph. This trip used 39 litres of fuel:
Conversion: 4.54609 litres per gallon: thus 39 litres = 8.58 gallons.
342/8.58 = 39.86 miles/gallon
Converting to kilometres/litre:
39.86 * 0.35401 (conversion factor) = 14.11 kilometres / litre.
The car has 102,000 miles on the clock.
Sad old gits like me still work out their consumption every tankful….but not many others do,… do they?
I'm amazed how many folk take their mfa readings as gospel and believe they're doing 40 mpg in town! Mk1's are pretty good…but not that good.
I'm one of those 'lucky' people with a 99.9mpg reading, can't wait to see what Alicabrio and others find out about Hall senders…I've checked for vacuum leak and earthing points till I'm Lhasa green in the face!
Thanks everyone for your replies and advice. It's pretty clear that some problem somewhere is making my car a bit too juicy. Strange that there are no symptons other than me spending a lot of time in petrol stations. :?
I think I'll get the emissions checked as a starting point…
I will do so tomorrow, when I can get myself a spark plug spanner.
The fuel mixture adjustment screw sits between the metering head and the air intake flap, and you'll need a long 3mm allen key to adjust it. Clockwise is richer, and anti-clockwise is leaner.
You can set it up (roughly) by ear, or if you've got a CO meter you can do it more accurately. If you're doing it by ear, make sure the engine is warm through, the spark timing is correct, then mark the current position of the mixture screw.
Then richen the mixture until the engine struggles to idle, and mark that, then lean the mixture until the engine struggles, and mark that position too. The ideal position is in the middle of the two extremes, and the best economy is just slightly lean of this point.
HTH
Rich
i did that to mine
it works
and dont take long
just dont press down on the allen key, gently site it!
MFA reckons i do about 14 to the gallon, but then it also thinks it's -40 outside too!!!
'85 GTi Cabriolet
'80 Kawasaki KDX 175
'93 Kawasaki ZZR 600
'97 Chrysler Grand Voyager
You can fix your outside temp reading - see electrical FAQ's - tells you how to fix it.
M
I've adjusted the mixture screw so that I am slightly lean (1/16 turn) of the mid-point between lean-idle limit and rich-idle limit. I adjusted the idle setting to compensate for the new mixture setting and then took the car for a spin. The car is still really responsive on the throttle - no lag or anything.
I will change the spark plugs now and let you all know how my next tank of fuel goes!!
Thanks for everyone's helpful replies on this. I knew it was a good idea joining this site! 8)
PS. BTW. I had my full beam headlights on during this adjustment (as another post suggested) and smoke started coming out of the steering column! 8O Not good.
this might help - just ran 1983 cab (1.8 GTI) 279 miles on a mixture of A and B roads, some motorway and some city driving - 279 miles on 34 litres fules - gives 37 mpg - exhaust tail pipe colour is a light grey - just as it should be
m
