speedo drive gear lost in gearbox!
(In Topic #95251)
![whitesta in the usergroup ‘Local’ whitesta in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Does anyone know if this will cause catastrophic failure or how i could get it out. Cheers
james
that doesn't mean to say that i would recommend leaving it though.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Photo006_007.jpg)
![MK1Allan in the usergroup ‘Paid Member’ MK1Allan in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![MK1Allan in the usergroup ‘Old timer’ MK1Allan in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
If not then you will need to remove the box and try to fish it out. Mine took a while because it was stuck under a gear! If its not stuck then it will come out easy once you get a hold of it (its a poor shape for holding)
![woZa in the usergroup ‘Old timer’ woZa in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Anyway, had a look in the box but couldn't see anything. Needed to replace the green cap cover on the side and found it all chewed up in there. Didn't do any damage to the box though…
The drive gear seems to find its way to just below the access hole naturally when loose in the gearbox so if you drive it around next time you try to get it out it will be in the right place. I managed to drag upright with some long nose pliers with bent tips could grab it out.
Mine had a metal shaft stuck inside it where the cable brok so would have definately coused me probs eventually if i had left it however i called an old dude at VW and he said if its just the plastic gear they just get munched up so not to worry, just to make sure you change the transmission oil next service.
