Rocker cover earth...
(In Topic #94988)
First mk1 and first resto- 1983 golf gti black
You will do harm by intercepting these wires near the 'clocks' and soldering a new earth wire to any point near by . Drill and fit self tapper is fine . Oh and check you have decent earth from the battery lead to the engine block . Clean and shiny connections .
jumped said
sorry im still confused. so connect it from the engine block to a negative terminal? cheers
Sorry to confuse matters . What i mean is that the earth wire's for the clocks are as listed above and that the white/brown is the rocker cover earth for the MFA .
To supply an earth to the rocker cover , yes you can wire from engine block to neg terminal but it will be earthed with a large wire any way .
Have a look at the rear of the engine and make sure that a wire has not come adrift . This earth stops the MFA from working . Do a search on the site for more details
Cheers…….
