Electric roof switch problem
(In Topic #94461)
![JEVW in the usergroup ‘Paid Member’ JEVW in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![JEVW in the usergroup ‘Local’ JEVW in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
One 'bodge' that I have found is a wire connecting the permanant live from the ignition switch to the live feed from the fuse box (terminal K) which goes to the switch. Now I knew this would be there for a reason so I cut it off.
Now roof dosent work at all (not even with ignition on). Now, somewhere in the loom the switch must connect to ignition live, but is this done through a fuse? if so which one? I have a wiring diagram from bentley manual and it says terminal su on ignition starter switch.
Which terminal is ignition live on the back of the fusebox anyway?
Thanks in advance for any help you can give!
VW Golf Mk1 Cabriolet - Rivage In-Build. Again.
![Topoftherange in the usergroup ‘Local hero’ Topoftherange in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
if it worked alright before put it back!!
By putting a multimeter on the + that goes to the pump (in boot) and the +ve going to the switch, I get a complete circuit when the switch is switched. However when the pump is plugged in it dosent work.
Sorry if it sounds a little complicated, but I figure theres not that much too it.
