no indicators
(In Topic #94173)
no indicators
The hazards work off a different circuit so they can stay on with the ignition off.
Much luck with the MOT
Tian
<a href="signatyar.jpg picture by orrinb - Photobucket"><img src="http://img.photobucket.com/albums/v725/orrinb/signatyar.jpg" border="0" alt="Photobucket"></a>
am going to try a new hazard switch, and hope for the best.
any other ideas floating about?
here for a good time, not a long time
Change the fuse anyway as it maybe faulty, mine was but gave the impression of being fine on inspection.
Could be in the stalk but I doubt it tbh.
Someone else might have a brighter idea.
Tian :dontknow:
have tried a new fuse, but that didn't work.
hopefully someone can put us out of our indicator misery once and for all.
dji8785 said
i thought the indicator lights ran into the hazard switch.
Ther hazards work off a different fuse to the indicators. They are also on a different rated fuse too, 15A.
Try disconnecting the hazard switch and see if this makes a difference, I can assure you it won't.
Tian
I have had this with wipers and the horn playing up before and it cured it
i'll try the fuses again, and to clean the stalk itself.
the mystery continues.
Open it up carefully and see if there are any springs inside. These hold the contacts of the switch together, and if they're missing you often get the green light on the dashboard on all the time.
I have substituted one of mine that I lost with a bit of folded paper, and it seems to work ok.
HTH
Rich
1982 1.8 GTI Mars Red
check this is connected, (single wire as u stated)
ive had a few hazard switchs pack up on me on my old mk1's so if u have a spare or can get access to another one try it?
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
When I flick the switch to turn on the hazards all I get at a green light(stays on until I switch the hazards off) I have a 1991 cabrio. Help pls? I've brought a new switch and still have the same problem fuses all ok. Thanks
