Dodgy Battery?
(In Topic #94248)
Dodgy Battery?
First mk1 and first resto- 1983 golf gti black
Engine not running, no electrics on: 12.4-12.8 volts
Engine not running, headlamps on: not less than 12 volts
During starting engine: more than 7-8 volts
Engine running and battery light out (might have to rev it), just after starting: 12.8-13.4 volts, or thereabouts.
It sounds like the battery is knackered to me though, even if it wasnt charging it should last longer than a day, if the alternator goes then you will normally get the battery warning lamp glowing back on the dash, but not always
Take it into a kwik fit or somewhere simmilar, your not obliged to buy from them as they do "free battery check" which includes the charge rate etc
this time of year often kills battery cells, constant use of lights and heaters for short journeys and the cold can speed up killing an old battery off
