Top mounts
(In Topic #75747)
Top mounts
'83 Mars Red 1.1 C
Mk1 VW Golf 'c' restoration job....
Just wondering if there is an upgraded version like a "superflex" poly version?? Not too concerned about a harder ride, but keen to upgrade if possible?? :dontknow:
Stay out of the black…
And into the red….
You get nothing in this game for 2 in a bed!
And into the red….
When buying parts which are time-consuming to change (top-mounts, clutch kits, piston rings, etc), it's worth paying a little extra to ensure that you don't have to do it again too soon :wink:
If you use Ebay and do an advance search and look for seller Bonrath, you can then contact them by sending them a message. You may be able to purchase direct.
I think they cost around 65 pounds + P&P.
You can also get solid mounts but I would only recommend those for track day use.
Hope that helps
John
But will do a search on evil-bay, and see what it produces. I`ll probably opt for VAG ones from GSF to be honest..as easily available and a lot cheaper :wink:
And into the red….
And into the red….
am I right in thinking when the top mounts are shot (which mine are) the steering can be a tad unpredictable to say the least, seems mine is having trouble going in a straight line 8O
Make sure that the camber is set up properly, and then the tracking after putting the new mounts in.
also in need of 2 front tyres so will get them to sort the tracking out to then I'll be able to chuck it round corners once mroe
Have also got the tell tale sign of a shot top-mount. I can run my little finger between the bush and the metal plate.
Are they easy to swap, or is special tools required like an impact air gun etc..? :?
And into the red….
And into the red….
Bozlem-Boy said
oh dear… i too am now experiencing heavy handling![]()
You'll need spring compressors to safely open the McPherson strut assembly when you get it off the car (unless you have shorter-than-VAG lowering springs). DON'T open the big nut at the top without them - the spring, under pressure, will launch everything above it (spring-seat, top-mount, assorted nuts and washers, the spanner you're holding, etc) into whatever it's pointing at (your head, your ankle, your child…).
I opened one at the scrappy, to get a less rusty spring-seat, while pointing it at an old bonnet which was propped up against a wall - the "missiles" made one inch-deep dents in the bonnet from 8 feet away 8O
You will also need a full front alignment after re-assembly, but everything else can be done with a good socket set, etc
must admit that "missle" tale made me chuckle, and glad that no-one was hurt. It sounds like the sort of trick i`d do…
And into the red….
And into the red….
However, what stunned/scared me was the level of energy released - the spanner just disappeared out of my hand, and any of the flying items would have broken anyone's ankle if they'd been in front of the bonnet…
just done the top mounts, new tyres all round, balanced and tracking.. actually steers where I want it now :y:
And into the red….
And into the red….
they've made the suspension and steering sooooo much better!
On my 1996 Subaru, I was replacing my rear struts, but was going to wait until morning to buy a spring compressor. My friend got impatient and grabbed a rope and a long socket bar to tighten down the spring. Folks, this is a perfect example of what NOT to do:
His Arizona methods offended even my red-neck Texas sensibilities!
Impatience always leads to the mother of all fook-ups!
Het JPX are you from the sunny states then?? :dontknow:
And into the red….
And into the red….
Probably the original one that came with the car.
