help, 1.8 cab overheating!
(In Topic #90104)
Are you saying the car runs on when you walk away?
Which hoses look frayed?
Three things spring to mind:
1. Wiring fault (as it gets hot goes high resistance). This is third on my list of likely problems but you never know
2. Do a compresion test, it'll cost you ?15 for the kit and will tell you an awful lot. This will show up head gasket problems and poor compression
3. My third and final answer would be your a/f mix being way out, might be worth checking that whiley ou're there
sounds like fans workin ok.
splutterin at higher revs is thebiggest indicator but more info required for sure.
fuel pressure test i reckon.
rebuild in progress....
