75' Golf S Automatic Restoration (Not 56k friendly)
woZa said
You think your garage is small. That is like a mansion compared to mine! I can just get out of the car if it is parked right up against the other side… And I'm no lard arse either! :wink:
That actually made me feel better about my garage
The blinker light is missing a piece so I had to try to fix it.
I took an old "regular" tail light and cut out the blinker glass.
Then I cut out the broken blinker glass from the early tail light.
And finally I put them together after hours of grinding and cutting plastic with my dremel wannabe tool.
woZa said
That's some nice work on the taillight… And a swallowtail rear panel 8)
Yea, I got the swallowtail panel from a guy on vwvortex forum.
The shipping cost a bit, but I really wanted to restore the car back to the way it was (except for the motor/tranny, i might upgrad it)
Peter.
1980 1600 GTI, daily driver.
But before I can weld on the rear panel I have to recreate some of the rails, where the bumpers are mounted.
Does anyone know how it's supposed to look like?
I'm not quite sure how the outer piece and the bottom piece…
As you see, the other side is a bit rusty so I'm not sure if it's completely as it should look like originally….
I'm also thinking of putting this baby into the car :?
1982 Golf 1.1 C
Anyone know how to stop bad luck?
What's the engine you're hoping to put in?
Rich
mcscrew said
Looking good!
Rich
Can't you tell? :wink:
It's a Audi A4 1.8l 20v N/A which I'm going to run Dellorto DHLA 45 carbs on.
I just have to figure out what I'm going to do to with the ignition…. :dontknow:
oh and what did you use when you covered it all up again?
austin said
bringing life into an old thread, just a question, did you sandblast all the underarch sealer off or get handy with the grinder?
I did use a grinder with a wire wheel on to strip off the body sealer.
It's a long and dirty job
marsredgti said
i want to know what you polished your rims with?! 8O
I sanded the wheels down until I got a smooth finish (2000 grit).
Then I used Autosol and a polishing wheel on a electric drill.
Sorry but I don't have any update pics yet.
I lost my will to work on the car for a while and I've been busy renovating my bathroom/appartment so I haven't had any time to work on my car.
The inspiration for working on the car is slowly coming back though
