dash rev counter and lights problem
(In Topic #84936)
Following advice on another post i installed an extra earth cable from the brown cable in the multiplug to the metal bracket the clocks sit on behind the dash but it hasnt made any difference. Is this a good enough earthing point?
Before they stopped completely they would die intermittently and could be brought back to life with a thump on the dash so is there anything that could have worked itself loose? All wires on multiplug are firmly attached and not melted through as far as i can see. The clock works so its definately getting power. The temp guage also went a little haywire and suddenly went to max and started flashing at the time the dash died.
Any ideas on what's stopping these working?
If you have lost tacho, petrol gauge, coolant temp gauge & warning light, oil pres w/lt & buzzer, charging [alternator] w/lt & indicator w/lt, this is where to look.
MP
