we're leaking:(
(In Topic #83980)
![Thegreg in the usergroup ‘Local’ Thegreg in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
we're leaking:(
Greg 8)
1981 Golf C 1.1
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
![The Campaigner in the usergroup ‘Local’ The Campaigner in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I've got a wet passenger side footwell although mine is in the front. Have you checked the plastic seals behind the door cards?
I have noticed that when I wash my car there is evidence of water which has run inside the door and the out at the rear of the door into the footwell!!! It comes in at the rear of the door where there is a cutout, maybe worth a check!!!!
As for my leak, any help would be appreciated. The water appears to be coming in behind the dash, and drips down by the fuse box into the footwell. I have had a look up by the ign module and wiper mech, but there doesnt appear to be anywhere the water could be getting in??? has anyone else got to the bottom of a leak like this??????
All help appreciated!
Jamie
http://i169.photobucket.com/albums/u210/TheCampaigner/100_1444.jpg
Member 125 - 2005
Greg 8)
1981 Golf C 1.1
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
Member 125 - 2005
![skid in the usergroup ‘Local’ skid in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I found this another place that was leaking in when i tested mine.
Strip all the carpet out and dust down with talcum powder and this will then show once it leaks again where the water is coming from. :wink:
![tash in the usergroup ‘Regular’ tash in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Should that tray should have a seal to stop water getting in or holes to let it out? If it has drainage holes, where are they?
1991 Helios Blue Clipper Cabby
Slightly Damp
Slightly Damp
![1stgolf in the usergroup ‘Old timer’ 1stgolf in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
tash said
I have small water feature going on too in my clipper. All these ideas are going to help fantastically. I had noticed some water in the tray under the windscreen when I had the bonnet up the other day.
hi if your on about the scuttle thair should be 2 drainage holes 1 each side hope this helps
<img>
this has gradually got worse, probably to do with all the rain we'v had recently but its a problem i noticed the rear passenger side footwell got damp, then a week or two later it went soggy
I have this on and off and after considering boot seals and side screen seals finally found the cause in my case - holes in the rear of the sunroof drain tray :roll: . If you have a factory fitted sunroof, this can develop leaks around the four exit points of the drain tubes - two the rear and two to the front. The water leaks onto the headlining, but not through it (hence no sign of leaks without headling down) and finds its way down either the B or the C posts and into the footwell or boot.
1983 1100 C
1983 1100 C
![Prowler in the usergroup ‘Old timer’ Prowler in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
…here….
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.vwgolfmk1.co.uk%2Fimages%2Fdrain1.jpg)
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.vwgolfmk1.co.uk%2Fimages%2Fdrain2.jpg)
2000 (Mar) Passat Sport Estate 1.9 TDI (ATJ) 5 speed automatic with Tiptronic - TUG 2 (Remap and cruise control by CCC)
Quite hard to see in there on mine with blue paint, thanks for your pics.
I hope that works.
![](https://i145.photobucket.com/albums/r209/civdis/P1010003.jpg)
Slightly Damp
Slightly Damp
![Growers in the usergroup ‘Local’ Growers in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
In both the passenger and driver footwell there is a hooked tab of metal cut out of the floor just after it begins to rise toward the bulkhead (I think they're for securing the carpet/sound proofing).
After leaving the car overnight in the rain on my sloped drive (nose down) I accelerate up the road and water pours into the footwells from the afore-mentioned holes!
Has anyone else had this? Any suggestions as to how the water is getting into the cavity between the 'inner floor' and the bulkhead?
